Permatex for Baseray nipples?
Adam E
Member Posts: 43
Hi all. It's been a long time since I was here!
In response to one of my own posts many years ago about BaseRay, someone mentioned that one should use Permatex on the nipples before installing. Is this the consensus? If so, which kind? I know there's many different types.
Thanks.
Adam
Thanks.
Adam
Dope
Regular pipe dope (Hercules Pro-Dope) works just fine. The dope should be applied evenly to the entire nipple and the press-fit will seal.it.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
