making a conversion
LRR
LRR Member Posts: 1
I have had two plumbers give me estimates for a burner.  The first one suggested a new liner in the chimney and the second suggest to avoid the chimney and get a higher effeciency burner.  I am confused..any suggestions.  Two zones, 2600 sq. feet, have baseboard heat and live on long island.
  • STEVEusaPA
    Can you give us a little more info???
    What did each person propose (equipment, oil/gas, piping changes, control strategy,etc)?
    Please leave out the pricing.
    Either application can work fine, depending on all the other factors.  Luckily neither one suggested not relining the chimney.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    edited May 2012
    Condensing
    I would recommend a modulating/condensing boiler. We install many on LI with excellent results.Can vent with polypropylene pipe saving the expense of a stainless chimney liner and will yield much greater eff than a cast iron boiler. Some nice Nat Grid rebates now also
