laars jvs minitherm pilot but no burner
TSV_Skibum
Member Posts: 3
I have a Laars Minitherm JVS. I have a pilot but no burner when the t-stats call for heat. It appears, the cut off circuit (flame roll-out , blocked vent , hi-limit) has continuity but I am not able to measure voltage anywhere. In addition I jumpered the entire protective circuit and still no burner and no function of the automatic flue damper. It appears the pumps are working and t-stat side is also functional. I
time to call a pro
jumping out the safety equipment is a bad idea even for a test. With the proper tools a decent pro will beable to get to the bottom of this for you and get the proper parts.Cost is what you spend , value is what you get.
cell # 413-841-6726
noted, thank you
noted, thank you0 -
Check the fuse
Inside a little black plastic holder (to the left of the transformer and relay) there is a fuse. If it blew, replace it with an identical one. The vent damper must operate before the firing cycle. You can manually open the damper (gently), and either place a switch in manual position or relocate a jumper wire inside the damper motor cover to provide temporary heat. Put the safety string back exactly as it was! That type of boiler can and WILL clog up and spill products of combustion (Carbon Monoxide). They have a recommended cleaning schedule.0 -
checked fuse
the fuse was good, I defeated the safety string while I was there with no intention of running for more than a few seconds to isolate the problem to the safety string. After the test all safeties were returned to the as designed configuration
Subsequent to this posting, I found the problem to be the hi-limit switch. The factory recommends its setting be 190 degrees, I found it to be set somewhat lower, about 140. I reset the dial to the factory setting and the unit worked. What bothers me is why the as found value was 140 in 1st place. I am watching the operation closely, everything seems to be nominal.0
- 120.2K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
