outdoor reset and hydro air
mikedo
Member Posts: 301
with a hydro air system what is the lowest water temp. that people are running without blowing cold air on the homeowner ?
I have...
Depending on the customer and air system design, typically 130 degrees. Some at 140 degrees.0 -
hydro air
at 140 do you even need a condensing boiler ?0 -
"Do you even need a condensing boiler"
What's the return temp if the supply is 140? How about the modulation component of the picture?0
