baseboard heating - hearing water sloshing around
elfie
Member Posts: 266
hearing water sloshing around the pipes near the boiler and in the base board pipes
is this air in the pipes?
how do I get rid of the air? could it be another problems (water was replaced in system after the pressure relief valve was replaced)
thanks
thanks
Sounds like
air. It could have entered the system when the relief valve was replaced. There should be some kind of air elimination device on your system (automatic air vent, Spirovent, etc.); the trick is to get the air to migrate to that device. Do you have someone that services your boiler?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
auto air vent
i located the auto air vent above the expansion tank and above an air scoop
i pressed it and it release some air
it doesnt seem to be doing it automatically - should it??
thanks0 -
air in system
It is air in the system. What is your water pressure at??? It should be at 12 PSI.
lack of water pressure will cause the system to trap air.0 -
air / water pressure ??
system pressure when cold & full should be 15 psi minimum....when hot higher...maybe as much as 24 psi...// 1156...extrol tank...& gauge should all be changed with relief valve...// that eliminates "free" call backs two..or 3 days after relief changed...0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
