Expansion couplings
PCerra
PCerra Member Posts: 9
Hi folks
I have a 10 year old house with hot water baseboard heat.  The heating system is extremely noisy with pinging, I guess from expansion.  Personally I think the plumbing contracted screwed up the job and made all the pipe holes too tight going through the walls and floors.  I read on this forum that there "were" some 3/4" copper expansion couplings.  I cannot find them on line.  Does anyone know if these are still available?  If so where can I buy them?  If not are there any suggestions on how I can quiet this system down?  It's worst if the temperature differental in and out is large.  Thanks in advance.
Pat
  • RJ_4
    RJ_4 Member Posts: 484
    baseboard
    Sounds like you may have air in your system   I would suggest having a hydronic heating contractor take a look at it.
  • RobG
    RobG Member Posts: 1,844
    Noisey Baseboard
    Is this a new problem or has this been ongoing since original installation? If it's been going on for 10 years, it sounds like expansion problems. If that's the case you may want to look into an outdoor air reset controller and constant circulation. It may not cure the problem entirely but it will create a slow, constant expansion and contraction that will definitely help. Could you post some pictures of your boiler and near boiler piping as well as some pics of your baseboard ends. The more info the better.
    Rob
  • PCerra
    Additional details
    Thanks for the replies.  Yes this has been going on since day one.  I
    thought it would have subsided by now.  It is very annoying.  The heat
    works great, just real noisy pinging and creaking.   I thought the
    expansion tank was supposed to prevent this.  When you touch the pipe
    when the heat is on, you can feel the pipe on the radiator expand, like
    it is pressurizing.  I will post some pictures of the boiler setup.
    Thanks again
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,424
    The expansion tank has nothing to do with
    the expansion of the piping, just the water volume in the system as a whole. running an out door set back control and constant circulation can help with expansion noises as the pipe changes less due to a more even temp that ramps up and down due to the change in the heat loss of your home. SImply the water in the pipe gets warmer as the outdoors gets colder. This also reduces fuel usage as you only heat the water to the temp you need at that time, not to max temp for a short time then off.
    cell # 413-841-6726
    https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating
  • PCerra
    More info and questions
    I am attaching some pictures of my setup.    Do my gauge settings look normal?  Also would it make sense to put a pressure gauge in the pump coupler to monitor the pump pressure?  Could it be too high and causing more expansion?  It looks like there is a plug there that is 1/4 inch in the photo.
    How would I go about connecting the system as suggested to keep the water circulating?
    I appreciate the assistance.
    Pat
    The pressure is not causing the expansion noise!!
    The heating of the copper is causing it.
    cell # 413-841-6726
  • PCerra
    Options for controlling expansion
    Thanks for your replies.
    It sounds like I need to control the expansion to reduce the noise.
     Are there still expansion couplings available?
     Where can I learn more about outdoor setback controls?  Is this a complete controller unit that gets wired into my existing controls?
    Pat
    They are called
    an expansion compensator not coupling
    cell # 413-841-6726
  • duffy_4
    duffy_4 Member Posts: 79
    Expansion noises
    That's not a 1/4 plug ,it s a shutoff isolation flange
  • meplumber
    meplumber Member Posts: 673
    Seek out some professional help.
    We all try to offer good advice here. And sometimes that advice is for you to seek out professional help. Now is one of those times. You are obviously way over your head here. If you start to fool around with your system with the limited knowledge that you are exhibiting here, you could do some serious damage to the system, your house, or worse, your family.
    Time to step back and seek out a competent heating professional. Tell him about the noise and let him find and correct it.
    Good Luck.
  • PCerra
    Thanks for all the input
    Thanks folks I appreciate your comments and input.
