2 pipe radiator Q....
kcopp
kcopp Member Posts: 4,682
Went to do a service call on what I was told was a HW heating system. Upon arriving the  system was clearly a 2 pipe steam system. The radiator looks like it has been repaired many years ago w/ JB-weld or the like. The repair has failed. So in order to stop the water from making a mess I disconnected the radiator and capped it off.  Much to my surprise there was a good deal of water in this radiator (3 gallons)..... Does this mean that the steam trap has given up the ghost and needs to be replaced? ty,kpc
  • gerry gill
    gerry gill Member Posts: 3,084
    I would believe so
    otherwise the trap should have been open allowing draiange..it is also possible it is clogged with rust or gunk and is open but clogged..
    gwgillplumbingandheating.com
