radiator valve
dmw
dmw Member Posts: 1
I'm having trouble finding this valve, it's 1/2" IPS strait on a hot water sunrad and it looks to be a 1/4 turn valve with a paddle inside instead of a ball. Any thoughts? The house has this in every room and the home owner wants to keep everything the same and the only radiator valve i can find around here are muti turn and that wont fit. Thanks
  • icesailor
    icesailor Member Posts: 7,260
    Sunrad Valves:
    Those were the common valves we always used on those radiators. They all had the "paddle" gate inside. They weren't positive shut-off valves.
    Someone like Steamhead can probably tell you everything you would ever want to know about where you can get them.
