burnham recalls
SCOTTY2HOTTY
Member Posts: 1
I HAVE COME ACROSS THREE CAST IRON, 4 SECTION, OIL FIRED BOILERS THAT ARE LEAKING IN THE SAME PLACE WITHIN THE PAST 2 MONTHS. ALL WERE MADE BEFORE 2000. IS THERE SOME KIND OF RECALL OR INFORMATION THAT I CAN GET ABOUT THESE UNITS FOR MY CUSTOMERS. I CAN'T SEEM TO NAVIGATE THE BURNHAM SITE TO WELL. THANKS!
good luck
Those are V-7 boilers, which are no longer casted. You can try finding a Burnham rep near you. They won't deal directly with you, always thru a supplier. There will be little to nothing left on warranty. You may be offered a break on an MPO, or V-8, if you are lucky0
- 120 Geothermal
- 394 Solar
