High efficiency gas boiler installation
HW
Member Posts: 1
in Gas Heating
How important is it for the installer of a high efficiency gas boiler to be trained by the specific manufacturer? Is there a different technology for each manufacturer's design, or is the technology and installation process similar for most but with certain minor adjustments so anyone trained in hight efficiency gas boiler installation can do a reasonable job?
Short answer yes
Only issue comes at the set up of the controls. Each make is a little different, but with some due diligence and time reading manuals, anyone can do the set up.
Piping is virtually the same from one make to the next.
The real key is proper sizing of the boiler to the heat load of the structure, and not over sizing for any reason. Otherwise, you will have a basket case on your hands.0
