How much oil have I lost
memnosine
memnosine Member Posts: 7
I'm losing pressure in a solar Bray oil system, and haven't found a big leak. But how big a leak would account for this: I've lost 4 psi -from 16 to 12- in two months since repairing a cut line on the roof (long story). I have six each four-by-eight foot arrays, and three each one-by-two meter arrays. I've found a leak of about one drop in a week or two; how fast must a leak be to account for the loss I'm seeing? It's not in the heat storage tank (at least I don't think so, this oil is lighter than water, isn't it?)
    hot_rod Member Posts: 27,702
    total system volume?
    it would be tough to guess without knoiwing how much the system holds, how much actually leaks, etc.
    I would think any DHW coil or HX would have double walled heat exchangers and the oil would be visible, via a leak path, before it could cross into the potable water supply.
  • memnosine
    Bray oil next step
    Thanks for the comeback.  The oil -it's really a high temp hydralic fluid-  is not getting into the house water. The fluid in the transfer tank is clear, no oil sheen. I've touched almost all the pipes, joints, and find no drip. It's a mystery I'd like to solve.  Is there a sniffer like for natural gas? Someone who specializes in this?
  • michael_34
    michael_34 Member Posts: 304
    expansion tank
    It may be leaking into the expansion tank. Is there any swings in the PSI or is it holding at 12?
  • memnosine
    edited March 2012
    Pressure swings
    The pressure changes with the temperature of the oil, from a low of twelve at night to a high in the low twenties during a sunny day. I've extracted the data for the residual pressure when the array temps are from below forty and plotted the accompanying pressure, as attached.
  • memnosine
    pressure swings
    It appears that the attachment dis not make my last post; I'm pasting the data here.
    ----------------------- Page 1-----------------------
        Sheet1
    Date               Array #1           Pressure
                                       38                 16
                                       38                 16
                                       33                 16
                                       31                 16
             Feb 03                    27                 15
                                       31                 15
                                       27                 16
             Feb 04                    38                 16
             Feb 08                    17                 14
                                       31                 15
             Feb 09                    28                 15
                                       32                 15
             Feb 08                    17                 14
                                       31                 15
             Feb 09                    28                 15
                                       32                 15
             Feb 10                    30                 15
                                       26                 15
                                       24                 15
             Feb 11                    24                 15
             Feb 12                    16                 14
                                       22                 15
                                       22                 14
             Feb 13                    26                 14
                                       28                 15
                                       34                 15
                                       32                 14
             Feb 15                    32                 14
                                       34                 14
                                       30                 14
             Feb 16                    37                 15
                                       31                 14
                                       32                 13
                                       24                 13
             Feb 18                    33                 14
                                       37                 13
                                       28                 12
             Feb 19                    25                 12
                                       25                 12
                                       24                 12
                                       24                 12
                                       27                 12
                                       32                 12
                                       34                 12
             Feb 20                    30                 12
                                       35                 12
             Feb 23                    28                 12
        Page 1
    ----------------------- Page 2-----------------------
        Sheet1
    Feb 26                        17                   12
    Feb 27                        38                   12
    Mar 06                        30                   12
    Mar 10                        32                   11
    Mar 13                        39                   12
    Mar 19                        26                   12
    Mar 20                        28                   12
        Page 2
  • michael_34
    edited March 2012
    New Expansion Tank
    It is more than likely your Expansion tank is failing or not sized properly. First check and make sure that the air bladder of the tank is pressurized to the pressure. If you keep your system at 30psi, then the bladder should be 3-5 PSI lower. I have seen the wild swings handful of times on systems. It not unusual for this to happen.
    Always make sure the expansion tank is rated for solar temps.
    Good luck
    Michael
  • memnosine
    Stable now, close the thread
    I've checked every pipe, every joint, each array, and checked the tank and the heat exchangers. No oil leaks anywhere. Pressure has stabilized at 11-12 psi. How do I close this thread?
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,874
    Hydrin bladder a MUST....
    If not, it WILL fail, eventually.
    ME
