Indirect DHW on Steam System
I am in an area where there still are many steam systems. I am curious to if there is an advantage to using a steam boiler to heat the DHW through an Indirect compared to a gas power vented DHW.
try posting this
in the Strictly Steam forum. More specialized eyeballs on it there.0 -
Only real
benefit is hot water recovery will be faster usually, and domestic production capacity is also usually higher then standard tank type heaters. The main reason is burner capacity.
Typical stand alone water heaters have a 40,000 btu burner. An indirect will have whatever burner capacity the boiler has. (usually more then 40,000)
Drawback is no redundancy, if the boiler fails, you have no heat or hot water.0
