boiler choice time
Bobbyd2727
Member Posts: 27
in Oil Heating
Based on heat loss calculations for my 3000 sq ft home of 138,000 btu, I have had two heating contractors recommend: the BurnhamMPO147 with an outdoor reset with an Alliance SL 35 gallon indirect water tank, and the Buderus G215/3 with the logomatic and the buderus S120 32 gallon indirect hot water tank . Each contractor is comfortable with the installation and is highly recommended. This is one tough choice! I see the specs compare at Burnham: burner capacity 1.05gph,DOE heating capacity 129 MBH , IBR water rating 112, AFUE 87% , water capacity 11.08 gallons. The Buderus: burner capacity 1.1gph, DOE heating capacity 134MBH, IBR water rating 117, AFUE 86.3%, water content 12.9 gallons. Can anyone comment on these choices?
We install both
More MPOs than Buderus , but both are great choices . What brand boiler are you replacing ?
If you decide on the MPO and you like to look in on the system to see what's going on , I'd recommend having the optional LCD display installed also .0 -
replacing an oldie
I'm replacing a thirty five year old cast iron Texaco fuel chief 139,000 btu boiler with a high speed beckett burner. I'm hoping to save at least 25% on fuel oil. What do you think?0 -
Buderus
Buderus would be my choice,we do about 50/year and the average savings is over 30%0 -
138,000?
How did you come up with that? Awfully high,that's over 41BTU/Sqft,something is not right0 -
Not that high.
Robert, I frequently have heat loss calcs reveal 42-43 btu/sq ft on old houses up here. With an old Texaco Chief, I would fair to guess that the house is at least 100 yrs old.
I don't think that his heat loss is that high if he is in an area with a -6 to -10 design temp.0 -
Not that old
The Texaco was a rebadged Dunkirk sold from the early 60's to the early 80'. Texaco bought Paragon Oil in 1960,anything older than that would be a Paragon. And with regards to the heat loss quite a coincidence the heat loss is exactly the same as the existing unit,no? 41 BTU/sqft and the heat loss calc coming out the same as the unit already there are both major red flags!0 -
house was built in 1971
Both contractors just walked through the house and said those boilers would be the ones to use since I have vaulted ceilings in the kitchen and dining room and half of the main zone was on a slab they added btus because of those last two factors. but did say 128000 to 138000 was a good estimate0 -
Heat loss calc
In your original post you stated that a heat loss calc gave you 138,000. Was one done?
I misread earlier. I thought that he said he had a Texaco burner. Most of those that I see are on coal conversions. My mistake Robert. I can safely say that I have never seen a Dunkirk installed in my coverage area.
What is the OP's location?0 -
Added BTU's?
I'd be shocked if the heat loss was more than 50% of 138K. Do the math now or pay for the wasted oil forever!0 -
fuel consumption for heat loss
Bobby, how many gallons of fuel do you normally burn per winter?0 -
gallons burned per year
In a typical cold winter here on Long Island about 1000 gallons a year. thats with the temperature set to 66 degrees fronm 3P.M. to 11 P.M. and set to 60 degrees at night and most of the day when we are at work.I'm using a programmable thermostat. This year with the warm winter maybe will use 800 gallons. I don't think these contractors did an accurate heat loss calculation because I got 61,000 btus with an estimated on line program. If thats the case how would you size the boiler?0 -
Sounds about right!
for a 3K sq/ft house on LI. The smallest triple pass boilers are larger than that so the decision is pretty easy, you should see an easy 30% reduction. I'm on LI and that is the average results we've been getting.0 -
choosing the right size boiler
So then would the smallest Buderus Logano G115WS be a good choice? The smallest size that is chimney vented outputs 85,000 BTU's.0 -
Yes
That would be my recommendation. I would also use a reset control,either the AquaSmart or Logamatic,depending on the application0 -
Thanks for your advice! I'd love to have you over for an estimate! Are you near East Islip?0 -
The G115/3
probably fits about 85% of the single family residences on Long Island. The climate here on the island is really not very severe in the winter. I put a G125BE/21 (73,000btu's) in my brothers 2500 sq ft home in Oakdale just about a year ago, he estimates about a 50% savings.
http://www.technicalheating.com/sites/default/files//styles/large/public/DSCF5262.JPG0 -
Nice
Nice work as always!There was an error rendering this rich post.
Agreed
so which Buderus did you end up using?Baltimore, MD, USA
Consulting0 -
It's a G115WS/3
Frank firing 0.7GPH, I expect the customer to save at least 30%.0 -
At least!
nice work.Baltimore, MD, USA
Consulting0 -
new boiler
My thanks to Bob and his great team! This new system is quiet and working efficiently to save oil already. Its been five days and the reading on the logamatic display indicates five hours of operation which essentially means I,ve used about 3.5 gallons of oil! Its gotten down into the forties at night. It not only looks beautiful but works great as well!!0
- 125 Chimneys & Flues
- 120 Geothermal
- 169 Indoor-Air Quality
