leaking slant-fin boiler
hydronx_3
hydronx_3 Member Posts: 35
Just checked out a boiler that is leaking between the first and second cast iron sections.  Homeowner wants to try and have it taken apart and fixed before thinking about replacing it.  I have busted quite a few apart on their way to be recycled but told him I have no confidence it putting one back together and thinking it won't still leak.  Anyone have experience?  It is a slant-fin, not sure if the sections have push nipples or gaskets.
  • billtwocase
    billtwocase Member Posts: 2,384
    push nipples
    Is it really worth doing? I'd say probably not
  • kcopp
    kcopp Member Posts: 4,687
    is that...
    a steam or Hot water boiler? If its steam you MAY have a  better chance w/ boiler sealer. I would give Slant/fin a call...
    Steamhead Member Posts: 18,537
    Don't even bother trying to repair it
    with that much leakage, the push nipple has rotted out and the mating surfaces in the sections are probably damaged. It's scrap.
    Check with Slant/Fin to see if it's still under warranty. If so they will back it.
    Is this a steam or hot-water system?
    Consulting
  • hydronx_3
    edited March 2012
    hot water
    Hot water.  Floor piping is polybutylene which might be the problem,  Am I right in assuming there is no oxygen barrier with polybutylene? 15 year old system
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,565
    Dont waste you're time or hard-earned $$$$$$$
    New Boiler.   Mad Dog
  • Mad Dog_2
    New Boiler.   Mad Dog
  • Mad Dog_2
    New Boiler.   Mad Dog
  • Steve Whitbeck
    Steve Whitbeck Member Posts: 669
    oxigen barrier
    If you install another cast iron boiler it will get eaten up also.
    Install a COMPLETE stainless steel and brass system or use a heat exchanger between the boiler and the in floor tubing.
  • kcopp
    Most PolyB...
    tubing was Non-barrier. If it is just grey non barrier . If it has a red coating on it then yes barrier. Your looking at a new boiler and some sort of HX to separate it from the ferrous parts...or going completely non ferrous. looks like a lot of money going into the system.
