30 PSI
MikeyD
Member Posts: 1
The pressure is too high in my boiler so the pressure relief valve is opening and spurting out a little water. I bled the radiators and the pressure went back down. A couple days later it is back to 30 psi. Not really sure but does this mean my expansion tank is waterlogged? should I drain it? ...or just call a professional?
maybe
Could be your expansion tank is full. Could also be that the water feeder that let's water into the system is leaking by. Could also be a problem with your hot water coil or indirect water heater, depending on what you have. When in doubt, call a pro!0 -
Might also be...
That the expansion tank is charged to high..
I went out on a service call where the boiler was doing the same thing... The home owner had the expansion tank replaced a few months prior... It was a domestic tank... they come precharged at +- 55 psi... and the installer never checked the pressure he just installed it.. It's a good tank to use... it won't rust... but the pressure needed to be more in line with the system so I lowered it to +- 18psi & the boiler was fine after that...
It's not likely the problem but it could be so might as well consider it...
:-) KCA
Hope that I helped:-) Ken0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
