was told this wont work
stev0
Member Posts: 11
If its...
just baseboard why the primary /secondary? Seems overkill. It will work provided the end of the primary loop goes to the boiler....0 -
o
im going to ad 1more zone on the manifold. i did p/s because im going to use the optional buderus controls that ramp the boiler down and just wanted some insurance for the flu gas cond0 -
The piping layout
is fine, but if the boiler output is 94,000 btu, then you should be using 1 1/4 pipe, not 1 inch.0 -
point of no pressure change
I think the air scoop is backwards. in the photo the water should go from right to left on the primary loop.Cost is what you spend , value is what you get.
cell # 413-841-6726
boiler piping
If it's the G115WS it's 1-1/4" supply, 1" return0 -
its a ga 124/23 1" supply &return
1"0 -
The only thing that I can see
worth mentioning might be
1. 1" pipe can carry about 75,000BTU so 1 1/4" might be a better choice..
2. Add a flow check on the secondary circuits to prevent that nasty Ghost flow..
Hope that I helped
:-) KCA:-) Ken0 -
Delta-T
A pipe size does not equate to btus it equates to gpm and gpm is based off that good ole hydronics formula. A 25 degree delta isn't going to hurt and you can move 7.5gpm thru 1" pipe.
gpm = btuh / ( delta-t x 500)
7.5gpm = 94,000 / 12,500
What's with the rainbow of circs?There was an error rendering this rich post.
no hot water zone?
Is there an indirect in this systems future?There was an error rendering this rich post.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
