Leaking Bushings - Hot Water Boilers
LSF
Member Posts: 3
Anyone having difficulty with larger (5" - 6") bushings leaking at threads on hot water heating boilers such as Peerless 211A or Weil McLain LGB series? We have tried all commercial products we are aware of. The bushing will hold for a day or two and then leak, sometimes an actual stream of water.
the commercial install guys
i work with use pipe wicking on fittings 3" and up. I never used it myself though, but seems to work for them...There was an error rendering this rich post.
Did you....
I've noticed with larger bushings made "elsewhere", there is usually a line that looks like a seam running across the threads. Always thought it was where the dies stopped. Perhaps it is a seam.
How about a nipple and reducer coupling?There was an error rendering this rich post.
Agree
Wicking , pipe dope and nipples with reducing couplings ... I for one avoid bushings , good in a fix ... I am also not comfortable using them in a cast block ...There was an error rendering this rich post.
