Resol M
Ben_17
Member Posts: 18
<span><span>
<span style="font-size:16pt">Heating circuit relay allocation</span></span></span>
<span style="font-size:16pt">arrangement/heat.circuits/heating circuit/</span>
<span style="font-size:16pt">expert/hc relay var.</span><span><span>
<span style="font-size:16pt">selection: 1, 2, 3</span>
<span style="font-size:16pt">factory setting: 1</span><span><span>
With the parameter “HC Relay var.“ it is possible to choose
different relay allocations for the heating circuit pump and
heating circuit afterheating. Factory setting “1“ is the standard
relay allocation (see 3.5).</span></span>
Does this mean I could do injection mixing?</span></span>
