Protected Oil Line
Nick_28
Member Posts: 20
in Oil Heating
I have approx 65' LF of 3/8" dia copper oil line from 2 oil tanks piggy backed to the boiler. Was thinking of replacing or abandoning that line and add/change it to 1/2" OD dia Oil Pro-Tec. Anyone have experience using this product from Kamco or is there other mfg's equivalent?
Protected Oil Lines:
If you live in Massachusetts, your oil lines should have already been converted to this oil line product. As far as switching to 1/2" OD, you can use it if you like to spend more money on something. 3/8" OD covered is more than plenty for any size oil burner you have.0
