Is this how 1 CPH works?
FJL
Member Posts: 354
This is my understanding of how 1 CPH heating works: at 3:05 pm, t-stat calls for heat. Boiler turns on. T-stat is satisfied at 3:20 pm. Boiler turns off. The boiler now won't turn on again until the next one hour mark even if the t-stat calls for heat before then. In my example, that would be 4:00? Is that correct?
CPH setting
Your assumption is wrong. The CPH setting is in the Tstat so if the tstat calls for heat the boiler will run.0 -
You are correct . . .
I worded my post improperly. I understand that the setting is in the t-stat. What I should have written is that the boiler won't turn on even if the temp in the room falls below the temp setting of the t-stat until the one-hour mark, which is 4 pm in my example, b/c the t-stat won't call for heat until the one-hour mark.0 -
Re: CPH
Check out this thread: www.heatinghelp.com/forum-thread/128816/visionpro-thermostat-problem. Give a read check out the links0 -
Thanks . . .
I guess I had forgotten about that thread.0
