Swing check valve and Circulator with build-in flow check
heatingFun
Member Posts: 84
My Burnham gas boiler manual asked a Swing Check Valve and then a Boiler Loop Circulator in the Boiler Loop. But the plumber installed a Taco 007 Circulator with a build-in flow check.
I was told the FLow Check valve is not the same as the Swing Check valve.
Should I ask next plumber to change the installation to follow the manual?
The manual page is attached here.
The flow chek
is fine.....and much better. You'll possibly hear the swing check clanking away...annoying when it happensThere was an error rendering this rich post.
