System 2000 or Buderus?
maine
Member Posts: 4
Our boiler is shot and we are trying to decide whether to replace it with a System 2000 or a Buderus. The quote for the System 2k is approximately $8k, while the quote for the Buderus is about $10k. I have confidence that both companies would do a good job with the install. And so my question is: what system is better? I define better along three metrics: how long will it last? how efficient is it? how much maintenance will it require? Any assistance would be appreciated.
No pricing please
The rules of the site are: Please be nice; don't discuss pricing, and don't post advertisements.
Both systems have a good reputation. Did each of the contractors do a heat loss calculation of your home? Did then mention a chimney inspection or relining?0 -
Contractors
...did not do a heat loss evaluation. Neither said anything about the chimney, though we just bought the house and had the chimney inspected.
Thoughts?0 -
What are....
the details of you house? Size? Type of Radiators? What is in there now? Bathrooms? # of kids? # of zones? Is Nat gas available?0 -
House
Our house is 3200 sqft; currently using 3 heating zones (one for each floor); forced hot water base boards; four bedrooms; no kids at the moment, but will be in the future; natural gas not an option (unfortunately); we have a failing Burnham V-14-a-t0 -
What model Buderus? and chimney
From the prices you gave, I think the System 2000 contractor gave you a price for an EK1 and the Buderus company gave you a quote for a larger boiler. You need to determine which size boiler will be sufficient to heat your home. Maybe the Buderus contractor based his sizing by the size of your present boiler? That may be too big; has there been new windows or insulation added?
I would recommend that you have the chimney lined with a stainless steel liner (smooth wall) if it is not already there. The stainless steel liner is able to better handle condensation than a terracotta liner especially if it is old.0 -
Buderus
The recommended Buderus model is the G-115-4.
Does the chimney liner change you recommend impact my decision, or is it simply better regardless?0 -
As a homeowner, not a contractor, I suggest ...
... that you dump both contractors and get one that does do a heat loss. I have no confidence in contractors who do no heat loss (for hot water; different techniques are required for steam).0 -
System 2000
Hands down in my book0 -
I'll
second the vote of "No Confidence". You either get it right now, or you live with it. Did either contractor sit down with you and discuss current levels of comfort in the home?0 -
Ill ask....
Where in Maine.?0 -
Both
I would recommend a chimney liner with both brands unless the terracotta/chimney there is relatively new.0 -
Sure you need a new boiler?
HO here; just wondering what the diagnoses were of the two contractors about your old boiler. If you re-insulate THEN do a heatloss, you may be able to use a smaller boiler. It's spring in 5-6 weeks. Can you tough it out and in spring re-insulate, do a blower door test, catalog your entire system--radiator sizes, locations, pipe runs and sizes etc., do heat loss and THEN install a boiler in the summer? Are those two bids comparable apples to apples. include indirect for domestic hot water, all required permits, etc?0 -
system 2000
i will 2nd. the new jersey made system 2000...have installed & serviced many over the years...very economical....very efficient..BUT get some one to do a heat loss, & have old chimney lined, will be much better & also code issue in Maine if present chimney not in really good shape...// if "home inspector" looked at chimney, have a chimney mason inspect it ... PLEASE for your own safety, as most "home inspectors" do not really do very thorough job, just my $.02 worth...the person that inspected my house 30 years ago knew less than me, & my knowledge was only heat...& plumbing....0
