Radiator Paint Question
berm
Member Posts: 14
I recall reading in one of Dan's books that steam radiators painted with metallic paint (silver or bronze) will give off 10 to 20% less heat than those painted with nonmetallic paint. Several of my radiators have been spray painted silver metallic. To switch to nonmetallic paint do I need to strip the silver paint off or can I just paint them over in white or black? Cosmetics aside...is this worth the effort.
1
emissivity
Sounds like you want to get that 10-20% back that the silver paint has taken away. Painting right over it will work. For more information, try searching the wall for "emissivity" Much has been written on the subject0 -
I'll try that.0 -
Painting
I recalled reading about this a while ago, here are some useful links:
http://www.heatinghelp.com/files/posts/6704/Radiator%20Paint%20Effect%20With%20Thermograph.pdf
http://www.heatinghelp.com/article/158/Radiators/1265/Does-the-Color-of-a-Radiator-Matter0
