9 units
jrbayside
Member Posts: 81
How difficult is it to convert from steam to water heat?
more
work than it's worth. IMHO...0 -
have you performed the test yet?
vent off--with assistant by the boiler, fire it and see if air is coming out of the vent tapping of the cold riser radiator.
warning, steam coming out of the radiator will remove wallpaper in 15 minutes, or human skin in 5 minutes!--nbc0 -
9 units
I did fire it up to 75 to kick the boiler on and went to the long run which gets hot to within 5 feet of the tee to go vertical. I took off a 3/4 plug to see if any steam came out, it didint. Then i put a lighter over the hole and the flame was sucked in. Im thinking of putting a large hoffman valve there and see if it helps. What do you think0 -
Piping problem?
It sounds like it's time to draw up a rough diagram of the system showing what parts work and which don't. Include rough pipe sizes and check the pitch of everything with a level, also show the location and types of vents. Old systems develop sags that are very effective at stopping steam and there is a good chance positive harm has been done by those who don't understand steam.
Post that diagram and some photos of the piping (especially coming and going from the boiler) and we'll see what can be done to get the system working the way it's supposed to.
If you do convert over to hot water be prepared to replace all the pipes and the radiators because that might be exactly what you have to do. To many start out thinking they can just covert the boiler and change the controls and then the real fun starts; what waas going to cost a few grand ends up costing tens of thousands.
3PSI gauge0 -
9 units
how do I draw on the website to shoe the piping and related stuff that goes with it?0 -
Drawing
Hi- The best thing to do is to drawing out a schematic of your system on a piece of paper and then scan it and upload it to this website. The website will except both JPG and PDF files.
- Rod0 -
microsoft paint
is easy too.There was an error rendering this rich post.
