Auto Radiant Heat
Randy20162000
Member Posts: 2
Hi,
I will start by explaining my system setup, then explain the issue. I have a Buderus GA124 gas fired boiler, that is hooked up to a Buderus Logamatic 2107 controller, which is tied into an automatic valve that feeds a watts radiant heat 6 loop manifold. My problem is, when the temp outside drops below 32F, the radiant heat kicks on automatically. I can go and close the valve that is on the manifold, but the Buderus Logamatic sensing that it is cold outside, will kick it back on within a day. I have a thermostat in the main room where the radiant heat is (set to 59). All the thermostats in the house (3; 1 radiant; 2 forced hot air) are fed into a Taco relay controller. What I want to do is set the Logamatic, so I can control the radiant heat and not have it on automatic. Does anyone know how I would go about it? I included a pic of the automatic valve. Thanks
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
