Will Boiler Come Apart?
BrianCNY
Member Posts: 26
Hi All
I have a cast iron boiler from the 1940's that's uninstalled in my basement.
It looks like it's in 5 sections and held together by a metal rod on the front and back, but, I am only guessing since I have no idea how these are made.
I attached a picture showing the rod on the back.
I'd like to get this out of the basement and it would be much easier in pieces.
My question is . . . . If I undue the rods, and presumably use a hammer, will the sections come apart?
Thanks . . . Brian
Thanks . . . Brian
Hammers and wedges...
Yes, it will come apart. You have to "coax" it using an 8 pound maul, and wood splitting wedges.
They will calve off like loaves of bread, so be prepared to jump quick when it start shedding pieces.
To make it even easier, you could break the sections into even smaller pieces by continually hammering with the sledge on a given line until it starts sounding hollow, then give it a good hard smack and it will break in half.
Be prepared for a muddy mess. There are years of rust in those sections..
ME0 -
Dirty Jobs
It's a job for Mike Rowe. Wear old clothes.0 -
old boiler
There are guys that haul junk and scrap - call one of them and they should remove it for free just for the scrap. Scrap metal is going for about $1 for ten pounds.0 -
Removve for scrap
I wish I could find someone that will remove it for scrap but around here I still have to pay the guy if he has to break it up and haul it up the basement stairs. He generally wants a hundred bucks but he does a neat job and cleans up after himself. At my age a hundred bucks is a bargain compared to a couple weeks of back pain and a bottle of Vicoden.0 -
also
can be a dangerous job. Once the front or rear section comes off, it's game on. I generally use an old shower liner with plenty of old newspaper under the boiler. You will want to block up the middle sections. The legs are front and back sections, so there will be no support one it is separated. It's also a good idea to just loosen the bolts as opposed to totally removing them at first, and once the first section is off, tie a rope around the others to have control. This is also mainly if it is only you or have just one other set of hands. Good luck0 -
So many good ideas . . .
All are good ideas and I want to thank each and every
one of you for taking the time to read my post and reply.
I truly appreciate your help.
Brian0 -
Insurance?
If anyone comes in your house to demo and remove make sure they have the proper insurance. Safety as well as proper tools and knowledge/experience are key.0 -
Insurance is a great idea
Thanks for mentioning this.
I also have a liability release specifically for boilers. Someone purchased one from me last year and I had them sign this. It's not a rock-solid solution to being sued, but it can help.
I attached a sample release, but not sure if it will be readable.
If anyone wants a modifyable version of the release as a Word documnent, email me and I will send it to you.
Thanks again . . . Brian0 -
Be Careful!
When breaking up cast iron. Shards can come off with near bullet-like velocity and stick in your legs. Wear Eye protection too! Same for lookie-loo bystanders.0
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
