Telestats for Ipex manifolds
Does anyone know of a Telestat that will work on the obsolete Ipex manifold?  I believe the old part no. for Ipex was 488373 with end switch.  Where can I purchace 2 or 3 of them?  Thanks in advance.
This is what the fitting on the manifold looks like:
  • Plumdog_2
    Plumdog_2 Member Posts: 870
    Looks to me like
    Uponor actuators would fit. You may have to match up the threads with the correct adapter ring, then the actuator snaps on. You have to adjust the height as it sits on the thread to obtain proper closure.
