Burnham Baseray with Vacuum Steam
Hi y'all,
Tombig from the old days here with a query. Looked at a job recently, Historic ten story. Vacuum two pipe. Condo remodeler wants to remove standing iron and replace with Baseray. All piping 3/4" in and 1/2"out and routed relatively level through the subfloor. I haven't met the engineer yet but I assume he may have some rebuilt return traps for me to use.
In my research I haven't found a length limitation for two pipe. My longest is 14ft straight run replacing two rads. I would pipe as one plugging radiator two tees. If I'm careful about excess piping on the steam side I'm thinking I should be OK.
I've run plenty of Baseray before but only for hot water. Any hints or suggestions would sure be appreciated.
Tom Goebig
Delta T Mechanical
Chicago
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    replace radiators with baseray?
    is this for the whole building, or just one condo? if it is only 1 condo, it would be better to keep the same radiators as the rest of the building. otherwise the thermal mass will be different, and someone will be too cold, and others will be too warm!--nbc
  • Tombig_8
    Tombig_8 Member Posts: 15
    Hi Rise Vacuum
    Just one condo unit. 8th floor I believe. My piping is exposed, my output calcs are on, I see no problem. These buildings typically provide ample steam and rely on owner supplied TRV's for regulation. Does anyone know of one that fits well with CIBB?
