correct primary secondary piping setup
stev0
Member Posts: 11
hi doing a 4 zone manifold pri secondary loop with the boiler trim on the primary(boiler side) of the loop. my question is i have seen the pri circ on the supply and the return sides just wondering what the difference is. id be pumping away from the expansin tank either way whats the difference on pump location? thanks for any info
help?
As long as you're pumping away, you're fine. http://www.comfort-calc.net/primary-secondary_piping_tutorial.html0 -
anyone use this? http://www.caleffi.us/en_US/Technical_brochures/01084/01084.pdf
how good is this product?0 -
Hydronic Separator
I quit doing primary secondary piping over 5 years ago and have been using Calleffi's or Taco Hydronic Separators ever since. Less money, less time, better performance and a whole lot less hassle0
- 120 Geothermal
