Owner/Field service tech
charliechicago
Member Posts: 130
How do you skim a boiler
Generally speaking
run the boiler just below the steam point while feeding fresh water to the boiler and draining existing boiler water at the same time. Most manufactures also specify removal of the relief valve, and isolation of the boiler to streamline the process, and keep any chemicals in the boiler.
The draining at first will be at the water line (skim tapping). Also addition of chemicals for skimming is typical. Tsp is a popular one as is LYE (caustic soda)
It's best to follow the manufactures guidelines during this process, because the process can be involved, and also includes multiple steps. Usually taking a full day, sometimes more.
I'd give the steps, but the procedure would take too much typing.0 -
Skimming"the peerless way"
Well described furnace! Are there really 14 others?
Here are the peerless instructions for skimming (page 41)
http://www.peerlessboilers.com/DesktopModules/Bring2mind/DMX/Download.aspx?EntryId=85&PortalId=0&DownloadMethod=attachment
--nbc0 -
14 others
Do you mean 14 other furnacefighters?
That's a good one. LMAO0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
