How are we supposed to vent this thing?
crash2009
crash2009 Member Posts: 1,478
I have been helping a2shutt get an existing diagram on paper.  Now that it's on paper.  It is not like any one-pipe I have seen before.  It is neither counterflow, nor paralel, but a combination of the two.  Basicly its high on both ends with a drain (which is vented in the middle)  Looks like it works, just not sure where to put the G2's
The boiler is an IN-9, there is 1.25 cubic feet in Main 1 and 3.75 cubic feet in Main 2.  Existing vents 4 Hoffman 75's
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Looks Great
    Crash, excellent drawings for a strange system.  If I were doing it, I would put a the Gortons at the point furthest from the boiler.  The mid point where you wnat to maintain some venting by the condensate drips, I think the Hoffmans would be fine.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
    Steamhead Member Posts: 18,188
    I'd put all the vents at the ends
    so you would have all the vent capacity available to all the piping. No need to have vents at the drip points.
    Consulting
  • crash2009
    This post has been discontinued
    Will be continued here  http://www.heatinghelp.com/forum-thread/139857/Looking-for-input-on-my-one-pipe-system
  • Dave in QCA
    I stand corrected
    It seemed somehow that there would be some benefit from having a vent where the drip leg is, but of course there really isn't.
    Thanks Steamhead.
