polaris water heater help
AFred
Member Posts: 81
Has anyone had trouble with these?
I'm heading to a call where we put one of these in.
I'm told its chugging/gurgling on startup then wont lite(intermittent).
What the heck should I be looking for?
I'm planning on taking apart the trap and checking for issues.
Its only been in for 2-3 months.
Thanks for looking.
-Andrew
Thanks for looking.
-Andrew
Polaris
Check for a blocked drain line - too big of a trap.0 -
try the vacuum trick
Is there an in-line filter on the intake vent. Try hooking a shop vac with 2" hose up to the combustion air intake pipe near as possible to the base and run it for 10 minutes. See if this wiil get it going again.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
