How to drain water from the glass tube on a Weil-McLain Gold Oil Burner?
ChrisBuhl
Member Posts: 2
Hi,
I just happened to see that the glass water level tube on my boiler is maxed out. I can't figure out a way to lower the water level. I've called a couple of plumbers but not heard back, and I'm afraid to let the boiler run at all, but I also don't want my pipes to freeze. Can anyone help me figure out how to do this?
Thanks for any help,
Chris Buhl
Pittsfield, MA
Chris Buhl
Pittsfield, MA
Problem solved
Hi,
A friend came by and showed me how to drain it, problem solved.
Thanks,
Chris0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
