Hot Water boiler-with old cast iron radiators
Bob C._2
Bob C._2 Member Posts: 31
Hot water boiler replacement-with old cast iron radiators-2 pipe
2 story home-2nd floor radiators hot-first floor cold?
system has taco 007 pump
Suggestions?
larger pump?
best way to bleed?
thought air normally went to highest point?second floor
each radiator has manual air evtn-bleed not alot of air there!
  • furnacefigher15
    furnacefigher15 Member Posts: 514
    Well...
    If you don't get air, but water, then its not an air problem. It's a flow or balance problem.
    Is this a new system converted from gravity?
    If so, look for restriction plates in the radiator valves on the second floor.
    If this is not a new system, probably a bad pump, or no power to the pump.
  • Paul48
    Paul48 Member Posts: 4,469
    When
    you re-filled the system, did you bleed from the 2nd floor first?
