Proper Way To Mount a Low Pressure Guage?
ktccapo
Member Posts: 35
My old Peerless boiler has only the original 30 psi gauge installed. I'd like to add a low pressure gauge, namely a WIKA 611.10 Low Pressure Process Gauge, dry case, 2-1/2" dial, 0-3 psig range, 1/4" NPT lower mount.
Would the correct way to mount the gauge be to put it on a pigtail piped off of a new T on the stem on which the two pressuretrol pigtails are currently located (upper right hand corner of the picture I've attached)?
Your advice and suggestions are much appreciated. Many thanks and best...
mounting spot
that's the perfect spot, so you can see what the pressuretrol is doing, or not doing.--nbc0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 978 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
