crown maui combi
Steve_210
Steve_210 Member Posts: 664
can these be used with an indirect. the DHW demand is too high.
  • kcopp
    kcopp Member Posts: 4,663
    Use the Heat only....
    version w/ an indirect or a booster tank w/ a bronze/ss circulator or pipe it through a 20/40 gallon electric to give you a head start.
  • Steve_210
    the combi is existing
    I don,t see why i can,t use an indirect
  • kcopp
    I suppose....
    you could. It is just a shame to not use the coil that is in the unit. I did not realize this was an existing set up.
  • CMadatMe
    CMadatMe Member Posts: 3,086
    Storage Tank
    No need for an indirect. Dump DHW to a storage tank. Boiler is equiped with a hx for dhw.
  • Steve_210
    Thanks Chris
    I did look at that, but there is an unused indirect on site so I gave them number for, primary secondary pumping, 2 new circulators with DHW priority.
  • Steve_210
    My concern is
    Making the DHW Hx redundant . Is it safe to leave open ends, it does not seem safe to cap them. With no pressure on the domestic side could the boiler water ever Leak through the brased plate Hx .
  • Steve_210
    I seem to remember
    Doing this with combi boilers but that was 20+ years ago and I am sure things have changed alot since then. Anyone have any recent experience? Thanks.
  • Steve_210
    Bump
