cracked radiators
JohnT79
Member Posts: 3
What would cause hot water radiators to randomly crack. I replaced one about 3 months ago after a power outage( just figured it froze). A month later another one cracked on the same floor. And now one just cracked on a different zone. They were all working & bleed, didn't loose power etc
Cracked:
Either age or they froze.
Send pictures of cracked ones. It has to be cold for quite some time for them to split from ice.0 -
cracked radiators
It has not been that cold. But very unusual to have 3 radiators start to leak within 3 months0 -
cracked radiators
Not Unusual:
Not that unusual.
Three years ago, I bought a Makita battery drill set with Li-Ion batteries (2), a frill/driver and a charger. I doubt that I had 25 charge cycles on the batteries. I went to drill some holes and stuck a battery on the charger, The battery was bad but still working. It just wouldn't charge. I tried the second battery. It wouldn't charge either but the yellow light was on. I tried it on another like charger. One battery e=was bad, the other charged up. I can get another charger from Home Depot for $100.00 and another battery for #75.00. I should have bought a Milwaukee.
Post pictures of the cracked radiators. We will be interested to see them.0 -
multiple leakers
could there have been a spike in pressure which shoved several marginal ones over the edge?--nbc0 -
could have been ...
a number of factors over time. They might have frozen a long time ago and stressed them...maybe more than once. Tell us more about what you have for a set up. Boiler, piping, controls, age, how long you have been there, history....etc.0
