mono flow blues
toolman
toolman Member Posts: 1
can a small pump be add to a mono flow. I have a 8ft of base board bout 30ft away. yes its below the main.
sometimes i think i shooed had lunch some were else that day!
  • JStar
    JStar Member Posts: 2,752
    RE
    Yes you can! In fact, that's how the principle of Primary/Secondary piping came into this world. You can read about that in some of Dan's books.
    Just size the pump for your connected baseboard run, and have it pump away from the Monoflo main on the loop's supply line.
    But, out of curiosity...has this ever worked properly? Was it added to the system?
  • Paul48
    Paul48 Member Posts: 4,469
    Two monoflow tees, eight feet apart?
  • toolman1
    toolman1 Member Posts: 1
    mono flow blues
    some one eles added the register to the mono flow loop,and never got it to work. So I was asked to fix it.I have worked on boilers,but never this type of system.Will try to fix in the morning.I will let you know what happens.thanks cold in Michigan.
  • Paul48
    red stripes
    If you are going to try using 2 monoflows, make sure the red stripes are facing each other.
