Oil Boiler to Electric Boiler
Markian
Member Posts: 2
in Oil Heating
I have a FP Industries Dual Energy Boiler (electric 15KW(51,000 btu/h)/oil 22KW(76,000btu/h)) and I would like to replace it with a 100% Electric boiler. Electricity rates are under $0.06kw/hr here so it would reduce by heating costs. Any comments on how to size the boiler? I was thinking of going with a 19KW unit, producing 64,000btu/h., as the existing boiler already has the required circuit breaker and cable, but these can be upgraded if necessary.
The house is approx 20ftx40ft bungalow (1 floor + basement with the same dims, but not heated with rads).
Any help in sizing would be much appreciated. Thanks.
Mark.
Mark.
DO a heat loss
of the building. Just as you would for any other boiler change out.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
