Burner Hour Meters - Installed
AaronH
Member Posts: 59
Installed two hourmeters today, which coincided with an oil delivery. Now I can really track my usage and improvements!
The boiler's unit is wired in parallel with the oil valve, and the hot water heater's is wired in parallel with the burner motor. Both seem to be working well and keeping accurate time of when the oil is being sprayed.
I went with analog meters so they could be read when the burners are off, they also measure 1/100 of an hour. Eaton/Cutler Hammer 7-7-65-4848PM-406 ($16.45/ea)
