Over Pumping Solution, 2nd Try
Rich Davis_2
Member Posts: 121
A couple months ago I comissioned a complete system, using a TT PS60, one zone with 4 loops. Problem is that I only get
2nd Try
The reason that your post is getting cut off is because you probably hit the "control/trl" instead of the "Shift" key when typing or "Shift/Enter" at the same time when typing. Either way, you hit a wrong key and it sends your posting. You always do it at the same time and place. If I could figure out what your next word would be, I could probably tell you which.0 -
Useful hint?
Why not type up your complete message in (eg) Windows Notepad and then copy it into the Heating Help entry form??0
