Existing header re-pipe
dgordon
Member Posts: 7
Any opinions on re-piping this existing header? I am considering this because of how the branch tee's are laying on their side, my thinking was too rip out the old and rebuild the header with branches off the top per manufacturers specs. It is a 2 pipe vapor system. Any thoughts would be appreciated. Here are some pics
yes repipe it.
It will probably be easier for you to repipe it than to try to work with whats there..does that water heater in the background actually vent with that much conductor pipe? maybe its a distance illusion.gwgillplumbingandheating.com
for confirming, really didn't want to pipe to the existing. The water heater was there when we got there, nice install eh? (: I'm sure we will be addressing that as well. I'm kinda going in blind on this as the original contractor had the old boiler removed before I got there. From what I gathered it is a Trane 2 pipe vapor system, with rad. valves made by William S Haines Co., and traps I can't identify. Have you ever seen the name before?
Thanks again0 -
Re-pipe or re-use
Re-piping would allow you to re-route the hot water heater vent, and to cut out that old gate valve, which can be a headache later (in my experience).
Are you completely without heat while this is going on?--nbc0
- 87.1K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
- 49 Industry Classes
- 49 Job Opportunities
