Vapor System end of line trap replacement
elfie
elfie Member Posts: 266
there is an arco 911 trap positioned at the end of the main steam line on an Arco model k steam system (virtually all radiators still have arco valves and no traps/vents on any of the radiators)
my questions are:
any chance this end of line trap can be repaired (cant find any replacement kits for it) - maybe it can be cleaned with original parts kept??
if not salvageable, what might be an appropriate replacement trap? a basic Sarco f&t trap?
 its curious that the pipe below this trap connects to an underground wet condensate line (ie. not much room for air to vent from system I guess)  here is a pic of trap
    Steamhead Member Posts: 18,193
    That's a rare trap
    whatever you do, don't scrap it.
    The Tunstall and Barnes & Jones sites don't list kits for these. But first- is the trap working?
    Consulting
  • elfie
    edited December 2011
    arco trap evaluation
    may be tough to evaluate if it still works
    if its determined to no be working, can it be opened up and repaired/cleaned and shouldnt there be a strainer before the trap?
    i guess dirt trap should be cleaned out.
    guess it would be a big challenge to replace this trap
