Proper Way to Install Low Pressure Gauge Next to Vapor Stud
Derek_B
Do I need to put the low pressure gauge on a pigtail, or can I screw it directly into the tee next to the vapor stud? Any suggestions are welcome.
while not a necessity,
If you have them both on the same pig, if it clogs, both will be offline. Are you using a ptrol and the req'd 30psi gauge on a different pig? The way I set mine up was to have 1 pig for the low psi gauge and vstat with a shut off in line to isolate them during a blowdown, and another pig with the 30 psi gauge and my ptrol wired as a safety high limit switch if the vstat ever fails, and to take over during blowdown when the vstat is out of the equation.There was an error rendering this rich post.
like this ...1-pipe Homeowner - Queens, NYC
NEW: SlantFin Intrepid TR-30 + Tankless + Riello 40-F5 @ 0.85gph | OLD: Fitzgibbons 402 boiler + Beckett "SR" Oil Gun @ 1.75gph
installed: 0-20oz/si gauge | vaporstat | hour-meter | gortons on all rads | 1pc G#2 + 1pc G#1 on each of 2 mains
Connected EDR load: 371 sf venting load: 2.95cfm vent capacity: 4.62cfm
my NEW system pics | my OLD system pics0
- 120 Geothermal
- 394 Solar
