return drip
davem1
Member Posts: 13
I have asked questions about adding 10 ft of 1-1/4 steel fin baseboard to a one pipe steam system on the second floor. After much research and all of your input I now know I should have a return drip tying into the wet return in the basement. My question now is can I use 3/4 pex back under the baseboard and then down to the return
Pex?
Pex is not rated for the possible temperatures of the condensate.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
