Water leak at elbow connection at base of radiator under floor.
I have located a leak at the elbow connection of the steam pipe under the floor at the base of one of my radiators.  Can I take care of this leak by simply tightening with a pipe wrench?  Is this something I can do or should I call my boiler guy?  I'll post a photo.  thank you for any advice.
  • BobC
    BobC Member Posts: 5,566
    Be prepared
    Make sure that leak is at the 90 and not trickling down from the valve above. I would not depend on tightening up that joint unless I was prepared to replace the fitting - old steam pipes do not like to move.
    Bob
    3PSI gauge
