Burnham KV 85
2002 model with a hole above the water line. The returns are not leaking, what else could have caused this
    Steamhead Member Posts: 18,507
    Bad vents?
    That's the first thing to look for. Also leaky valve packings.
    Your boiler may still have some warranty left. Call Burnham with the model and serial numbers. They will probably suggest you go with a MegaSteam boiler, which is a much better unit that even has an anti-corrosion warranty- the only one in the business.
    Consulting
  • Steve_210
    Steve_210 Member Posts: 664
    Can I use the same burner. Do they make a gas burner in case the HO wanted to convert down the line.
    I will call burn ham 1st thing Monday . Thanks again
    edited December 2011
    Burner is different
    for the V8 and MegaSteam.
    If they want to go gas, Burnham won't support a gas gun in a MegaSteam. In that case I'd go with a Smith 8 or Slant/Fin Intrepid- with gas gun this setup will give better thermal efficiency than an atmospheric gas boiler.
    Consulting
  • Steve_210
    That's great
    Thanks again.
    For this and all your other posts
  • Steve_210
    Update
    Burn ham are replacing the block with a mega steam at a fraction of the cost of a new one
    Even though the existing is 11 years old.
    Great company, this is the real test, after sales service.
    11 YEARS after.
    And we are not the original installers.
  • Steve_210
    Update
    11 YEARS after.
    Excellent!
    Now find the leaks that made the V85 rot out. Bad vents, leaky valve packings, underground return lines.................
    Consulting
    worldclasshvac
  • Steve_210
    will do
    thanks again
