Viessmann Boiler
DRK
Member Posts: 2
Can a Viessmann Viodens condensing wall boiler be used to supply hot water for air handlers for hydro air. I don't seem to be making hot enough water. Thanks for any help.
Yes
Do it all the time. Are we not making or are we not delivering enogh gpm to the airnhandler. More info please. Which Vitodens? What size air handlers? What is the heat loss of each a/h zone? What size pipe to the a/h's? What pump are you using for the a/h?
Are we using a low loss header on the boiler? Are you running a 1.6 slope? If a 200 did we get the boiler out of nightine setback? Could ask dozens of questions.There was an error rendering this rich post.
Max temp
On the 100 and the new 200 is 176*,the older 200 is 167*To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Received
Your e-mail and sent you a reply. Need alot more info. Please provide it.There was an error rendering this rich post.
Hope
The call helped out. Let me know how you make out changing that zone pump.There was an error rendering this rich post.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
