Should my plumber know what I mean by 'clean and tune'
Mark_125
Member Posts: 56
Hi All,
I've had a home energy audit done and was told that my aging boiler for my 320ft addition has high CO output (130 parts per million). The engineer performing the audit also said that I could probably get my heating guy to do a 'clean and tune' and that should bring the CO back down.
I called my regular heating guy and he didn't seem to know what I was talking about....said something about packing the flue - should I be worried? Is clean and tune a common term for heating?
Thanks,
Mark
Thanks,
Mark
Worried...no
surprised yes. If the contractor does not then I would explain it to him. Opening up the flue pipe, look in in the fireways, brush and vac, pull the burners....do a combustion test. But there again if you have to explain that he probably does not have the tools to do that. I would start looking around.0 -
You bet....But you need a 'heating professional'
Not just a plumber.
If he says........"huh?" just hang up on him and call someone else.
If it's oil--complete cleaning, change & install proper nozzle, filters, pump strainer, and complete efficiency testing will either fix the problem, or determine if you need a replacement.
What kind of boiler? Gas or Oil? What burner on it.
What were the rest of the combustion numbers, besides CO? High CO can be caused by a number of factors. What do you have for draft, net stack temp, and excess air?There was an error rendering this rich post.
Natural Gas boiler
Should have included that its Natural Gas. The only other number he gave me was a draft of -7. I think I will take your advice Steve and call somebody else anyway. Thanks.0 -
clean and tune
sorry mike butmost plumbers are not equiped to do cleanings you dont say where you are located if we knew where you lived city state we might be able to help you more0 -
Yes your plumber should know what that means
This plumber would not say "huh" I would say "morning or noon what is the best time to schedule for you?"Cost is what you spend , value is what you get.
cell # 413-841-6726
Yes.
We do a clean and safety check for an annual fee for our service agreement customers.
Where we see an older boiler or evidence of a problem we do combustion tests, thermal scans, meter clocking, draft test, etc.
If these are foreign concepts to your plumber then you need someone else to take care of your boiler. Use your plumber to clear your clogged drains.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
