Indirect radiators
Just looked a a home with 7 indirect rads ,There are 12 rooms ,so they are shared (the indirects). Heating in the upper floors are directed by a lever in the duct work.The only way I can see to give uniform heat is to add a hot water loop . Any other ideas?
    Steamhead Member Posts: 18,186
    It had to have worked when it was new
    does it use only outside air? Are the inlet ducts open?
    Are all the usual steam-related issues (venting, etc) working as they should?
    Consulting
  • Gordon_7
    Gordon_7 Member Posts: 1
    indirect rads-add'l info?
    I am fascinated by this. It is steam, right? Any follow-up or other comments would be appreciated.
  • Jim Pompetti
    Jim Pompetti Member Posts: 552
    Work
    great ,first time I came accross ,this type of duct work on a steam system. Usually on a old hot air system.
